1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor problems(RBV can't update itself)
To: "Ron Sluiter" <[email protected]>
Cc: EPICS <[email protected]>
Date: Mon, 23 Mar 2009 14:53:36 -0400
Hello,
It gets more weird today.
I get "controller is not running. motor_init_record_com(): card does not
exit!" errors. The LED on IOvMAX board is green.
With dbior, I get the following:
	Oms MAXv motor card #0 @ 0x9FFFF000, id:
I tried reboot and still the same.
Huijuan
-----Original Message-----
Sent: Monday, March 23, 2009 10:09 AM
To: Xu, Huijuan
Cc: EPICS
Subject: Re: Motor problems(RBV can't update itself)
Hello Huijuan,
Is this a stepper or DC motor?
Since you mention the ERES field, I'm guessing this is a DC
motor. What is the value of the MIP field when the motor
is stuck in the Moving state?
Ron
Xu, Huijuan wrote:
> Hello,
> I'm using OMS MAXv motion controller. The motor record version is 6.3.
> The motor worked well several days ago with this version but goes
> weird when I use it today.
> RBV field can't update automatically. I have to reset the MRES or ERES
> field and just the two fields to update RBV.
> MOVN kept 1 all the time after motor began its first moving. DMOV does
> not reset to 1 after position is reached.
> Many thanks.
> Regards,
> Huijuan
RE: Motor problems(RBV can't update itself) Mark Rivers
Re: Motor problems(RBV can't update itself) Ron Sluiter
Motor problems(RBV can't update itself) Xu, Huijuan
Prev: RE: MEDM Comm. Failure / STATE Richard Pastrick
Next: RE: Motor problems(RBV can't update itself) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Motor problems(RBV can't update itself) Ron Sluiter
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
