1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM Comm. Failure / STATE
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 23 Mar 2009 11:31:25 -0700
I am not receiving the separate window which displays error messages for MEDM such as when the variable in question cannot be found. I am just seeing the toggling of Comm. Failure and STATE. I believe you might be right that it is the driver that is signaling an error. It could be a communication error.
I am using a Delta-Tau PMAC. It is the UMAC rack form factor. I am using the tpmac library to communicate. The IOC is connecting to all 32 motors on the Delta Tau and it is hosting 18 motors and 1 asynrecord. I don't know for the specific system I am debugging but on a different system I have seen an error message from Pewin when the IOC was running that communication had failed but this could be because of running USB and Ethernet connections to the Delta Tau at the same time.
I am going to try reducing the polling interval.
-Richard
-----Original Message-----
Sent: Monday, March 23, 2009 11:14 AM
To: Richard Pastrick; [email protected]
Hi Richard,
It is NOT a generic problem with running EPICS motors on Windows.  I do that all the time with no problems.  My motor controllers happen to be serial devices (ACS MCB-4B) , but that is not important.
Are you actually seeing error messages from MEDM, or just the motor status indicators (Comm. Failure, state, etc.) that indicate a problem.  I think the problem is that your driver is actually signalling an error state to the motor record, which is responding correctly.  You need to figure out if the driver has an error, if there really are communication problems to the hardware, etc.  What hardware are you talking to?  Delta-Tau PMAC?  If so, what library are you using?
From: [email protected] on behalf of Richard Pastrick
Sent: Mon 3/23/2009 1:07 PM
To: [email protected]
Subject: MEDM Comm. Failure / STATE
Hello All,
I have compiled an IOC to host motor records on Windows. Everything appears to be working ok but as soon as I launch an MEDM window, I intermittently will receive error messages from MEDM. On the motorx_all.adl window I see Comm. Failure appear in the upper right under the word RAW and next to status in the lower right box instead of NO_ALARM in green I see STATE in red. This also changes the state value just below that from 0x503 for good to 0x703.
The MEDM window is running on a Linux system and the IOC is running on a windows machine.  The IOC host has two network ports, one to the local network and the other directly connected to the motion controller hardware. This second Ethernet port is dedicated to only the motion controller hardware.
Does anyone have any suggestions for what might be the cause of this problem? Please don't just say Windows. I am actively looking into if it really is windows fault. I wouldn't put it past it because EPICS was not initially intended for windows and the compliance with BSD sockets code is not the greatest.
Richard Pastrick
Associate Software Engineer
Xradia Inc
5052 Commercial Cir
Concord CA 94520
925-288-1228 Ext 1151
925-771-8051 (direct line)
925-348-0384 (cell)
The information in this email, including any attachments, is confidential and intended only for the recipient(s) listed. Any use of this email for any other purpose is prohibited. If you have received this email in error, please notify me immediately by reply email, delete this email, and do not disclose its contents to anyone.
RE: MEDM Comm. Failure / STATE Richard Pastrick
RE: MEDM Comm. Failure / STATE Mark Rivers
Prev: RE: MEDM Comm. Failure / STATE Mark Rivers
Next: RE: Motor problems(RBV can't update itself) Xu, Huijuan
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: MEDM Comm. Failure / STATE Richard Pastrick
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
