Hi Emmanuel,
That looks like the problem I have reported in 2007 (and which is still "open"
in Mantis):
Summary gcc 3.2.3 bug: long integer values are corruped in R3.14.9
Description When writing integer values with a CA client (e.g. medm) to a long
integer channel (e.g. longout record), the upper bytes get corrupted. The lower
2 bytes are OK.
I can't see the error when the client is caput from base.
Client and IOC run on a linux-x86 machine.
The problem is new in 3.14.9.
See http://www.aps.anl.gov/epics/mantis/view_bug_page.php?f_id=0000291
It happens when using g++ 3.2.3 with option -O3.
Dirk
Emmanuel Mayssat wrote:
Hello all,
I have noticed oddities with my longout records.
Particularly when I use the soft Channel record.
record(longout, "myLO") {
field(VAL ,"100")
field(SCAN, "Passive")
field(DTYP, "Soft Channel")
Now if I create a medm text entry attached to this PV, and attempt to
modify the PV, it updates but not as expected. For example, if I enter
the value 10, the PV is updated to -11100023 (or something like that)
I am using medm 3.1.1 compiled against EPICS 3.14.9.
I have other longout records which are not "Soft Channel".
They correctly update with the same medm widget.
Any idea?
Emmanuel
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- longout record issue Emmanuel Mayssat
RE: longout record issue Mark Rivers
problem when running Channel Archiver zhangdemin99
<2009>
2025
2026
Re: longout record issue Andrew Johnson
<2009>
2025
2026
