Andrew,
I am on linux-x86 client and server.
VAL is as follow
-114301336 for entered values between 7 and 16 (10 being in that
range)
-114301335 for values between 17 ad 26
-114301334 for ... 27 ... 36
etc.
It seems to be an encoding problem.
caput/caget from a terminal prompt work correctly.
The val of the longout is incorrectly updated prior to the process
routine of the longout record.
E
On Tue, 2009-04-07 at 15:06 -0500, Andrew Johnson wrote:
> On Monday 06 April 2009 19:37:30 Emmanuel Mayssat wrote:
> > I have noticed oddities with my longout records.
> > Particularly when I use the soft Channel record.
> > record(longout, "myLO") {
> > field(VAL ,"100")
> > field(SCAN, "Passive")
> > field(DTYP, "Soft Channel")
> > Now if I create a medm text entry attached to this PV, and attempt to
> > modify the PV, it updates but not as expected. For example, if I enter
> > the value 10, the PV is updated to -11100023 (or something like that)
> > I am using medm 3.1.1 compiled against EPICS 3.14.9.
> > I have other longout records which are not "Soft Channel".
> > They correctly update with the same medm widget.
> What is your target architecture, for both the client and server? It is known
> that IOCs built against Base before 3.14.10 do not work properly on 64-bit
> architectures, so if you're running this on linux-x86_64 you should switch to
> the 32-bit linux-x86 target. The CA client code does work properly on 64-bit
> systems though, it's just the IOC that's faulty.
> With 32-bit linux-x86 clients I only see Dirk's issue when using old versions
> of caget and caput (not from Base, the ones from extensions/src/EzcaScan) and
> I suspect that's a due to a bug in ezca or in the caget and caput programs
> since all the other clients I've tried (including MEDM and Probe) do show the
> correct value for a longout record.
> Is the "-11100023" number you gave above correct? If not, please post the
> exact number that you get when you put 10 into the PV.
> - Andrew
- Re: longout record issue Emmanuel Mayssat
- longout record issue Emmanuel Mayssat
- Re: longout record issue Andrew Johnson
gensub constant char input parameter Emmanuel Mayssat
<2009>
2025
2026
<2009>
2025
2026
