1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: longout record issue
Cc: [email protected]
Date: Tue, 07 Apr 2009 16:22:33 -0700
Andrew,
Note that the values reported in the previous email are read from a
'text monitor' widget.
I noticed that in a text area, the longout do not update the same way.
In the TEXT AREA widget, I read
-1143013366 when 10 is entered
-1143013367 when 9 ...
etc.
E
On Tue, 2009-04-07 at 16:07 -0700, Emmanuel Mayssat wrote:
> Andrew,
> I am on linux-x86 client and server.
> VAL is as follow
> -114301336 for entered values between 7 and 16   (10 being in that
> range)
> -114301335 for values between 17 ad 26
> -114301334 for ... 27 ... 36
> etc.
> It seems to be an encoding problem.
> caput/caget from a terminal prompt work correctly.
> The val of the longout is incorrectly updated prior to the process
> routine of the longout record.
> Regards,
> E
> On Tue, 2009-04-07 at 15:06 -0500, Andrew Johnson wrote:
> > On Monday 06 April 2009 19:37:30 Emmanuel Mayssat wrote:
> > > I have noticed oddities with my longout records.
> > > Particularly when I use the soft Channel record.
> > > record(longout, "myLO") {
> > > 	field(VAL ,"100")
> > > 	field(SCAN, "Passive")
> > > 	field(DTYP, "Soft Channel")
> > > Now if I create a medm text entry attached to this PV, and attempt to
> > > modify the PV, it updates but not as expected. For example, if I enter
> > > the value 10, the PV is updated to -11100023 (or something like that)
> > > I am using medm 3.1.1 compiled against EPICS 3.14.9.
> > > I have other longout records which are not "Soft Channel".
> > > They correctly update with the same medm widget.
> > What is your target architecture, for both the client and server?  It is known
> > that IOCs built against Base before 3.14.10 do not work properly on 64-bit
> > architectures, so if you're running this on linux-x86_64 you should switch to
> > the 32-bit linux-x86 target.  The CA client code does work properly on 64-bit
> > systems though, it's just the IOC that's faulty.
> > With 32-bit linux-x86 clients I only see Dirk's issue when using old versions
> > of caget and caput (not from Base, the ones from extensions/src/EzcaScan) and
> > I suspect that's a due to a bug in ezca or in the caget and caput programs
> > since all the other clients I've tried (including MEDM and Probe) do show the
> > correct value for a longout record.
> > Is the "-11100023" number you gave above correct?  If not, please post the
> > exact number that you get when you put 10 into the PV.
> > - Andrew
longout record issue Emmanuel Mayssat
Re: longout record issue Andrew Johnson
Re: longout record issue Emmanuel Mayssat
Prev: gensub constant char input parameter Emmanuel Mayssat
Next: Re: gensub constant char input parameter Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: longout record issue Emmanuel Mayssat
Next: problem when running Channel Archiver zhangdemin99
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
