1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS for implementation of Remote Procedure call
To: Mahajan Kirti <[email protected]>
Cc: [email protected]
Date: Wed, 15 Apr 2009 08:43:06 -0700
Andrew Johnson wrote:
> On Wednesday 15 April 2009 07:52:19 Mahajan Kirti wrote:
>> How to implement Remote Procedure Calls using EPICS?
> Since the EPICS Channel Access protocol doesn't support the concept of RPCs
> natively, why don't you explain at a higher level what you're trying to
> implement using one and we may be able to offer suggestions for alternative
> techniques that *do* fit into the EPICS approach.
> - Andrew
We use (XML)RPC for some of our control system (specifically to reboot
IOC's under procServ), and have considered the use of an IOC with Stream
Device, to produce PV's which would communicate directly to one of the
RPC servers over the network.
This would be a round-about way to use EPICS for RPC's
S. Banerian
206-598-0302
University of Washington
Medical Center
Radiation Oncology
Remote IOC reboot Was(EPICS for implementation of Remote Procedure call) Emmanuel Mayssat
EPICS for implementation of Remote Procedure call Mahajan Kirti
Re: EPICS for implementation of Remote Procedure call Andrew Johnson
Prev: Re: EPICS for implementation of Remote Procedure call Andrew Johnson
Next: Re: EPICS for implementation of Remote Procedure call Elliott Wolin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Remote IOC reboot Was(EPICS for implementation of Remote Procedure call) Emmanuel Mayssat
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
