1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS for implementation of Remote Procedure call
To: [email protected]
Date: Wed, 15 Apr 2009 12:07:03 -0400
Hi Mahajan,
I'm not entirely sure what you are looking for. Would an interface between EPICS and an open-source publish/subscribe messaging package do the trick? I am starting work on an EPICS interface, but might be able to speed things up. I will also be at the Vancouver meeting if you want more information.
Briefly, a process on VxWorks could receive messages from the pub/sub package and do whatever is needed. The messages would be sent from the processing routine of a new EPICS record type. I've tested out the concept and it works fine. Now I'm learning how to create a new record type.
Note that the pub/sub packages uses an intermediate server written in Java. Usually we run it on Linux, but I suppose it could run on Windows or VxWorks/Java.
				Sincerely,
					Elliott
Those raised in a morally relative or neutral environment will hold
		    no truths to be self-evident.
Elliott Wolin
Staff Physicist, Jefferson Lab
12000 Jefferson Ave
Suite 8 MS 12A1
Newport News, VA 23606
757-269-7365
Prev: Re: EPICS for implementation of Remote Procedure call S. Banerian
Next: Re: EPICS driver for vacuum devices Geng Xiaosong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Remote IOC reboot Was(EPICS for implementation of RemoteProcedurecall) Pearson, MR (Matthew)
Next: How to get array and float at the same time by sscan 闫芬
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
