1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: How to get array and float at the same time by sscan
To: <[email protected]>
Date: Thu, 16 Apr 2009 10:11:42 +0800
Hi everyone,
I set up a 2-D scan as follows:
scan1 record: Drive is X motor VAL field, trigger is scanH.EXSC field. I set its detectors to be ADC.VAL, DAC.VAL and so on.
scanH record: No positions. Detector trigger is the field for starting  MCA. The detector is mca.VAL which is the array .
Now, I want to save the ADC.VAL, DAC.VAL and mca.VAL at the same time. But I can't get it. I find the data of ADC is later than the data of mca evenif  I set scan1.DDLY as 0. So please tell me how to gain the float data and the array data at the same time.
Thank you!
Best wishes.
Yan Fen
Yan Fen
Shanghai Synchrotron Radiation Facility
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
Zhangheng Rd 239,Pudong Dist.,
Shanghai 201204
China
Tel:+86-21-33933191
RE: How to get array and float at the same time by sscan Mark Rivers
Prev: RE: Remote IOC reboot Was(EPICS for implementation of Remote Procedurecall) Allison, Stephanie
Next: How to get array and float at the same time by sscan 闫芬
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS for implementation of Remote Procedure call Elliott Wolin
Next: RE: How to get array and float at the same time by sscan Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
