Hi everyone,
I set up a 2-D scan as
follows:
scan1 record: Drive is X motor VAL
field, trigger is scanH.EXSC field. I set its detectors to be ADC.VAL, DAC.VAL
and so on.
scanH record: No positions. Detector
trigger is the field for starting MCA. The detector is mca.VAL which is
the array .
Now, I want to save the ADC.VAL,
DAC.VAL and mca.VAL at the same time. But I can't get it. I find the data of ADC
is later than the data of mca evenif I set scan1.DDLY as 0. So please tell
me how to gain the float data and the array data at the same time.
Thank you!
Best wishes.
Yan Fen
=================================== Yan Fen Shanghai Synchrotron
Radiation Facility Shanghai Institute of Applied Physics Chinese Academy
of Sciences Zhangheng Rd 239,Pudong Dist., Shanghai
201204 China Tel:+86-21-33933191 ===================================
- Re: How to get array and float at the same time by sscan Tim Mooney
How to get array and float at the same time by sscan 闫芬
<2009>
2025
2026
RE: How to get array and float at the same time by sscan Mark Rivers
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
