1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Winsock errors
To: "[email protected] ([email protected])" <[email protected]>
Date: Fri, 24 Apr 2009 12:55:48 +1000
Hello,
I'm building a basic IOC under windows by doing the following:
makeBaseApp.pl -t ioc <name>
makeBaseApp.pl -i -t ioc <name>
Then I build the ioc, and run it without databases.  Upon exit I get the following errors
CAS: Client accept error was "WINSOCK Error 10004"
CAS: UDP recv error (errno=WINSOCK Error 10004)
..\online_notify.c: CA beacon routing (connect to "10.123.255.255:5065") error w
as "WINSOCK Error 10093"
or
CA cast server: Unable to fetch N characters pending
Has anybody had this error, and know how to fix ?
Thanks heaps,
Mark Clift.
This message and any attachments may contain proprietary or confidential information. If you are not the intended recipient or you received the message in error, you must not use, copy or distribute the message. Please notify the sender immediately and destroy the original message. Thank you.
RE: Winsock errors Jeff Hill
Prev: ITER call for expertise in the use of and development in the EPICS software environment Rees, NP (Nick)
Next: Winsock error10004 Mark Clift
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ITER call for expertise in the use of and development in the EPICS software environment Di Maio Franck
Next: RE: Winsock errors Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
