Hello Mark,
Ø CAS:
Client accept error was "WINSOCK Error 10004"
When the IOC core components were ported to other OS besides
vxWorks for EPICS R3.14 one task that was left unfinished was a well
orchestrated shutdown. Unfortunately, the only way to shutdown the original
R3.13 vxWorks IOC was to press the reset switch or remove power. That situation
isn’t really different in R3.14 except that now on Linux and Windows the
IOC is shutdown by abruptly terminating the IOC’s process. Many threads
in the system including the database processing, the CA server, device drivers,
actually nearly all of the threads in the IOC remain running when the IOC’s
process exits. The message you see are the last dying gasps from the CA server
threads when the WINSOCK shareable library is abruptly ripped out of memory.
I am consolidating to only one server code, and one side effect
will be gracefully shutdown of the CA server – installed first into EPICS
R3.15.
Jeff
I'm
building a basic IOC under windows by doing the following:
makeBaseApp.pl
-t ioc <name>
makeBaseApp.pl
-i -t ioc <name>
Then
I build the ioc, and run it without databases. Upon exit I get the
following errors
CAS: Client accept error was "WINSOCK Error 10004"
CAS: UDP recv error (errno=WINSOCK Error 10004)
..\online_notify.c: CA beacon routing (connect to
"10.123.255.255:5065") error w
as "WINSOCK Error 10093"
or
CA cast server: Unable to fetch N characters pending
Has
anybody had this error, and know how to fix ?
This message and any attachments may contain proprietary or
confidential information. If you are not the intended recipient or you received
the message in error, you must not use, copy or distribute the message. Please
notify the sender immediately and destroy the original message. Thank you.
- Winsock errors Mark Clift
Winsock error10004 Mark Clift
RE: Winsock error10004 Jeff Hill
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
