1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: DIfficulty with Libusb with EPICS
To: "Mehta, Pratik" <[email protected]>, <[email protected]>
Date: Thu, 7 May 2009 10:58:15 -0400
I have written a libusb code to send strings across to a power meter. I am successfully able to send strings across, but error occurs when I try to read the response from the meter.Can you please tell me am I going wrong?
#include <stdio.h>
#include <usb.h>
#include <time.h>
//clock_t start, end;
//double cpu_time_used;
// int argc, char **argv
int main(int argc, char **argv)
        struct usb_bus *busses;
        usb_set_debug(2);
        usb_init();
        usb_find_busses();
        usb_find_devices();
        busses = usb_get_busses();
        struct usb_dev_handle* usb_handle;
        struct usb_bus *bus;
        int c, i, a;
        char buf[255];
        char buf2[5];
        char* ptr = buf;
for (bus = busses; bus; bus = bus->next)
        struct usb_device *dev;
for (dev = bus->devices; dev; dev =dev->next)
/* Check if this device is a power meter */
if (dev->descriptor.idProduct == 0xCEC7)
        int i,stat,j;
                                printf("vendor: %04X\n",dev->descriptor.idVendor);
usb_handle = usb_open(dev);
                                if(usb_handle == NULL) {
                                        printf("Could not open device: %s\n", usb_strerror());
                                if(usb_handle != NULL) {
                                        printf("<<<Device Open>>>\n");
                                //usb_detach_kernel_driver_np(usb_handle, 0);
stat = usb_claim_interface(usb_handle,0);
        if(stat ==0){
 printf("Interface Claimed\n");}
                                        //printf ("stat:%d from claim\n",stat);
                buf2[0]='P';
                buf2[1]='M';
                buf2[2]=':';
                buf2[3]='P';
                buf2[4]='?';
        /*                      buf2[5]=0x38;
                                buf2[6]=0x31;
                                buf2[7]=0x30; */
              i=usb_bulk_write(usb_handle,0x02,buf2, 5, 10);
                                printf("write: %d\n",i);
        for(i=0;i<sizeof(buf2);i++)
                                        printf("buf2[%d]=%X\n",i,buf2[i]);
 j=usb_bulk_read(usb_handle, 0x81, buf, sizeof(buf), 10);
if(j < 0) {
        printf("No output\n");
        } else
                                        printf("read %d bytes\n", j);
                                   usb_close(usb_handle);
        return 0;
/////OUTPUT////
pratik-mehtas-macbook-2:~ pratik$ gcc exp4.c -lusb
pratik-mehtas-macbook-2:~ pratik$ ./a.out
usb_set_debug: Setting debugging level to 2 (on)
vendor: 104D
<<<Device Open>>>
libusb/darwin.c get_endpoints: building table of endpoints.
get_endpoints: Pipe 1: DIR: 1 number: 1
get_endpoints: Pipe 2: DIR: 0 number: 2
libusb/darwin.c get_endpoints: complete.
Interface Claimed
libusb/darwin.c ep_to_pipeRef: Converting ep address to pipeRef.
libusb/darwin.c usb_bulk_transfer: Transfering 5 bytes of data on endpoint 0x02
write: 5
buf2[0]=50
buf2[1]=4D
buf2[2]=3A
buf2[3]=50
buf2[4]=3F
libusb/darwin.c usb_bulk_transfer: Transfering 255 bytes of data on endpoint 0x81
USB error: libusb/darwin.c usb_bulk_transfer: transaction timed out
USB error: usb_bulk_read: An error occured during read (see messages above)
No output
Thank you,
Pratik Mehta
Re: DIfficulty with Libusb with EPICS Lawrence T. Hoff
Difficulty with edm installation Mehta, Pratik
Prev: RE: Failed to create single DLLs on Windows Wang Xiaoqiang
Next: Re: Motor Control - anyone have drivers and opinions for: SpiiPlus, Delta Tau, Parker ACR9000 So, Sung-Leung
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Difficulty with edm installation Mehta, Pratik
Next: Re: DIfficulty with Libusb with EPICS Lawrence T. Hoff
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
