1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Difficulty with edm installation
To: <[email protected]>
Date: Thu, 12 Mar 2009 13:42:21 -0400
Here is the complete log
pratik@pratik:~$ export EPICS_HOST_ARCH=linux-x86
pratik@pratik:~$ cd /home/pratik/epics/extensions/src/edm/
pratik@pratik:~/epics/extensions/src/edm$ make
make -C ./util install
make[1]: Entering directory `/home/pratik/epics/extensions/src/edm/util'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory `/home/pratik/epics/extensions/src/edm/util/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `/home/pratik/epics/extensions/src/edm/util/O.linux-x86'
make[1]: Leaving directory `/home/pratik/epics/extensions/src/edm/util'
make -C ./lib install
make[1]: Entering directory `/home/pratik/epics/extensions/src/edm/lib'
make[2]: Entering directory `/home/pratik/epics/extensions/src/edm/lib/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall     -DSINGLE_THREADED=1 -D__epics__=1  -m32     -g -fPIC -I. -I../O.Common -I. -I.. -I../../../../include/edm/os/Linux -I../../../../include/edm -I/home/pratik/epics/base/include/os/Linux -I/home/pratik/epics/base/include  -I../../../../include       -I../../util -I../../lib -I../../pvlib -I/usr/X11R6/include -I/usr/X11R6/include/X11    ../app_pkg.cc
In file included from ../pv_factory.h:11,
                 from ../pvColor.h:23,
                 from ../act_grf.h:31,
                 from ../bindings.h:26,
                 from ../act_win.h:43,
                 from ../app_pkg.h:36,
                 from ../app_pkg.cc:19:
../hashtable.h: In member function ?void Hashtable<T, o, N>::info()?:
../hashtable.h:177: error: ?cout? was not declared in this scope
../app_pkg.cc: In function ?void manageComponents(char*, char*)?:
../app_pkg.cc:308: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:315: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:486: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:493: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:590: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:693: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void managePvComponents(char*, char*)?:
../app_pkg.cc:764: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:771: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:925: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1019: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1122: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void ctlPvUpdate(ProcessVariable*, void*)?:
../app_pkg.cc:1189: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void selectPath_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1293: warning: unused variable ?item?
../app_pkg.cc: In function ?void abort_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1647: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void exit_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1675: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1690: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void shutdown_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1746: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In function ?void help_cb(_WidgetRec*, void*, void*)?:
../app_pkg.cc:1977: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:1981: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2002: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2025: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: At global scope:
../app_pkg.cc:2083: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::getFilePaths()?:
../app_pkg.cc:2478: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2551: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2599: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2614: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2548: warning: ignoring return value of ?int chdir(const char*)?, declared with attribute warn_unused_result
../app_pkg.cc:2594: warning: ignoring return value of ?int chdir(const char*)?, declared with attribute warn_unused_result
../app_pkg.cc:2611: warning: ignoring return value of ?char* getcwd(char*, size_t)?, declared with attribute warn_unused_result
../app_pkg.cc: In member function ?void appContextClass::buildSchemeList()?:
../app_pkg.cc:2843: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2850: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:2976: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?int appContextClass::schemeExists(char*, char*, char*)?:
../app_pkg.cc:3132: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3134: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::getScheme(char*, char*, char*, char*, int)?:
../app_pkg.cc:3175: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3177: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::createMainWindow()?:
../app_pkg.cc:3513: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3515: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3577: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3612: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3699: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3734: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:3775: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?int appContextClass::startApplication(int, char**, int, int, int)?:
../app_pkg.cc:4549: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4593: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4647: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4656: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4667: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4669: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4672: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4675: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4686: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4689: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4701: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4716: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc:4763: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::applicationLoop()?:
../app_pkg.cc:5444: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::postMessage(char*)?:
../app_pkg.cc:5544: warning: format not a string literal and no format arguments
../app_pkg.cc:5546: warning: format not a string literal and no format arguments
../app_pkg.cc: In member function ?void appContextClass::xSynchronize(int)?:
../app_pkg.cc:5739: warning: deprecated conversion from string constant to ?char*?
../app_pkg.cc: In member function ?void appContextClass::performShutdown(FILE*)?:
../app_pkg.cc:5801: warning: deprecated conversion from string constant to ?char*?
make[2]: *** [app_pkg.o] Error 1
make[2]: Leaving directory `/home/pratik/epics/extensions/src/edm/lib/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/home/pratik/epics/extensions/src/edm/lib'
make: *** [lib.install] Error 2
DIfficulty with Libusb with EPICS Mehta, Pratik
Prev: Re: Difficulty with edm installation Pete Jemian
Next: RE: Inter-IOC link problems Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: DIfficulty with Libusb with EPICS Mehta, Pratik
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
