1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Implementation of an EPICS IOC on an Embedded Soft Core Processor Using Field Programmable Gate Arrays
To: [email protected]
Date: Tue, 19 May 2009 10:51:02 -0400
Geyang,
I was reading your comments from yesterday.  That work is a little over 3 years old now.  I was able to compile epics and get an IOC prompt running on uClinux; however, it was a bit of a hack and calls to the global CTORs were never made during initialization.  Therefore, all I got was an ioc prompt and empty hash table with no commands to execute.  I did not pursue it any further beyond this point.  I was not gaining any momentum with the software team, and rightfully so, it was turning into a big mess.
The early days of softcores lacked MMUs and had to run uClinux.  Without full support of C++, calls to the global CTORs were not made along with a handful of other issues.  These days, softcores now have MMUs and can run full flavors of linux.  I would think this shouldn’t be too difficult anymore.  Just speaking from the hip here, I have done no further work on this topic since then.  I’m a hardware guy and don’t want to get into the business of owning/managing IOCs.
My platform of choice is going to be some flavor VME.  The interface is very well understood and easy to integrate into new designs.  If bandwidth is a limitation, I can always go with VXS.  Embedded IOCs are attractive when I can’t get to a VME crate or it is not cost prohibitive to add one.  If I’m going to run an embedded IOC, I would prefer running it over a softcore processor.  The interface is simple and there is very little cost adding it to a design.  Xilinx and Altera both have softcores with MMU support now.   Actel is running some variant of a soft ARM but I don’t know about an MMU.
I would shy away from fixed PPCs found in higher end Xilinx families.  I have read they are going to drop them completely in their next generation of devices.
If you’re looking to give it a try, I’d go with a Xilinx or Altera softcore throw in an MMU and run linux over it.
Doug
Prev: Re: Implementation of an EPICS IOC on an Embedded Soft Core ProcessorUsing Field Programmable Gate Arrays David Kline
Next: Compiling problems building EPICS base 3.14.10 on cygwin-x86 Pacios Rodriguez Luis Orlando
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Re: Implementation of an EPICS IOC on an Embedded Soft Core ProcessorUsing Field Programmable Gate Arrays Silver
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
