1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Compiling problems building EPICS base 3.14.10 on cygwin-x86
From: "Pacios Rodriguez Luis Orlando" <[email protected]>
To: <[email protected]>
Date: Tue, 19 May 2009 19:53:11 +0200
Title: Compiling problems building EPICS base 3.14.10 on cygwin-x86
I tried to compile EPICS base 3.14.10 on a windows computer with cygwin
I followed the install instruction, and compilation started correctly but
after a fews minutes, I had the following error messages:
make[2]: Entering directory `/cygdrive/c/epics/base/src/bpt'
make -C O.cygwin-x86 -f ../Makefile TOP=../../.. T_A=cygwin-x86 install
make[3]: Entering directory `/cygdrive/c/epics/base/src/bpt/O.cygwin-x86'
../../../bin/cygwin-x86/dbToMenuH.exe ../menuConvert.dbd ../O.Common/menuConvert.h
Error: Invalid character '#'
    at or before "#" in file "../menuConvert.dbd" line 1
Error: Invalid character '*'
    at or before "*" in file "../menuConvert.dbd" line 1
    at or before "*" indbToMenuH: Input errors, no output generated
make[3]: *** [../O.Common/menuConvert.h] Error 1
make[3]: Leaving directory `/cygdrive/c/epics/base/src/bpt/O.cygwin-x86'
make[2]: *** [install.cygwin-x86] Error 2
make[2]: Leaving directory `/cygdrive/c/epics/base/src/bpt'
make[1]: *** [bpt.install] Error 2
make[1]: Leaving directory `/cygdrive/c/epics/base/src'
make: *** [src.install] Error 2
Can anyone help me? I Would be very grateful.
Yours sincerely:
Luis Pacios
CIEMAT
Laboratorio Nacional de Fusión.
Madrid
Spain
---------------------------- Confidencialidad: Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si no es vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente respondiendo al mensaje y proceda a su destrucción. Disclaimer: This message and its attached files is intended exclusively for its recipients and may contain confidential information. If you received this e-mail in error you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited and may be unlawful. In this case, please notify us by a reply and delete this email and its contents immediately. ----------------------------
RE: Compiling problems building EPICS base 3.14.10 on cygwin-x86 Pacios Rodriguez Luis Orlando
Prev: Implementation of an EPICS IOC on an Embedded Soft Core Processor Using Field Programmable Gate Arrays Curry, Douglas E.
Next: Re: CSS Update John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Compiling problems building EPICS base 3.14.10 on cygwin-x86 Pacios Rodriguez Luis Orlando
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
