1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: where is ca_detach_context()?
To: <[email protected]>
Date: Thu, 21 May 2009 13:56:10 -0700
Title: where is ca_detach_context()?
I need to write simple CA client with couple threads. Both threads use CA. So I need to use ca_attach_context() and ca_detach_context() in second thread.
I can’t use ca_detach_context () in my program because compiler doesn’t find this function.
I checked manually and couldn’t find “ca_detach_context” in cadef.h and ca.dll files.
I do found “ca_detach_context” in access.cpp and CAref.html have it.
What is wrong?
I try to use Epics versions 3.14.9 and 3.14.10.
Thanks, Andrei.
RE: where is ca_detach_context()? Jeff Hill
Prev: Re: Can the saveData config file referencence another file? Tim Mooney
Next: RE: where is ca_detach_context()? Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
