1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: where is ca_detach_context()?
To: "'Liyu, Andrei V'" <[email protected]>, <[email protected]>
Date: Thu, 21 May 2009 15:31:31 -0600
Title: where is ca_detach_context()?
Hi Andrei,
You should see the function prototype, as follows, at about line number 189 in cadef.h.
“epicsShareFunc void epicsShareAPI ca_detach_context ();”
I see it also at ordinal 119 with symbol name “_ca_detach_context@0” when I run the ms depends.exe tool, and load ca.dll.
I am looking at the very latest version of R3.14, but I don’t expect that any of this has changed in the patch releases.
> I can’t use ca_detach_context () in my program because
> compiler doesn’t find this function.
Are you using the MS compiler? Perhaps you need to specify /MD to enable linking with multithreaded DLL runtime libraries.
Typical Windows MS Build Options
cl -c /nologo /D__STDC__=0 /Ox /GL /W3 /w44355 /MD -I. -I.. -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\acctst.c
link -nologo /LTCG /incremental:no /opt:ref /release /version:3.14 -out:acctst.exe acctstMain.obj acctst.obj d:/user/R3.14.clean/epics/base/lib/WIN32-x86/ca.lib d:/user/R3.14.clean/epics/base/lib/WIN32-x86
In summary, the following code runs in the preprocess in shareLib.h when it’s a windows compilation. As I recall, _DLL is defined by windows compilers when /MD (or the equivalent with a 3rd party compiler) is specified.
#       if defined(_DLL) /* this indicates that we are being compiled to call DLLs */
#           define epicsShareExtern __declspec(dllimport) extern
#           define epicsShareClass  __declspec(dllimport)
#           define epicsShareFunc  __declspec(dllimport)
#       else
#           define epicsShareExtern extern
#       endif
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Liyu, Andrei V
Sent: Thursday, May 21, 2009 2:56 PM
To: [email protected]
Subject: where is ca_detach_context()?
I need to write simple CA client with couple threads. Both threads use CA. So I need to use ca_attach_context() and ca_detach_context() in second thread.
I can’t use ca_detach_context () in my program because compiler doesn’t find this function.
I checked manually and couldn’t find “ca_detach_context” in cadef.h and ca.dll files.
I do found “ca_detach_context” in access.cpp and CAref.html have it.
What is wrong?
I try to use Epics versions 3.14.9 and 3.14.10.
Thanks, Andrei.
RE: where is ca_detach_context()? Liyu, Andrei V
Prev: where is ca_detach_context()? Liyu, Andrei V
Next: RE: where is ca_detach_context()? Liyu, Andrei V
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
