1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CA.pm
To: [email protected]
Date: Tue, 26 May 2009 16:05:17 -0700
(copy of a message sent to Andrew last week)
I am testing an API which uses CA.pm for Perl procedures. My specification says the procedure should abort when it loses
any CA connections.  So I've started a soft IOC, started this test
procedure, and then stop the soft IOC when it tells me to.  It sleeps
for a minute to allow CA to really disconnect (and there is a message)
but it never gets to the callback routine.  (Actually, it gets there
once during channel creation - but not when the channel really connects.) Am I doing something wrong here?
(This is a simplified version which cuts out anything not essential to this test. I was hoping I'd get it to work and then be able to fix the
version in my API.)
Thanks.
    Pam.
#!/bin/perl -w
# File:        CA_test_subsequent_disconnect.pl
# Author:    Pam Gurd
# Date:        May 19, 2009
# script to test the connectPVs routine in CPP.pm
# CVS    $Revision: $
#    $Date: $
#    $Author: $
# History:
#    $Log: $
use lib '/usr1/local/epics/release/R3.14.10/base/lib/perl';
use CA;
sub INT_handler (;$);
our $startupflag = 1;
my @message_log = ();
my $no_status=0;
my $channel = CA->new("TEST:DEV1:CUR", &connectionCallback);
$SIG{'INT'} = 'INT_handler';
$SIG{__DIE__} = 'INT_handler';
CA->pend_io(3);
print "testing connection for TEST:DEV1:CUR\n";
die "TEST:DEV1:CUR is not connected.\n"
           unless $channel->is_connected;
print "TEST:DEV1:CUR is connected.\n";
CA->pend_event(1);
$startupflag = 0;
printf("Stop the soft IOC and then press Enter ");
my $filename = <>;
printf("Wait 1 minute for EPICS disconnect\n");
sleep 60;
CA->pend_io(1);
CA->pend_event(1);
printf "3...";
sleep 1;
printf "2...";
sleep 1;
printf "1...";
printf "\nTest failed!\n";
sub INT_handler (;$) {
   my ($message) = @_;
   if ($message) {
       print $message;
       exit 1;
   exit;
sub connectionCallback ($$) {
   my ($chan, $connectionStatus) = @_;
   if ($startupflag) {
       return;
   print "connection callback!";
   if ($connectionStatus) {
       print " status=$connectionStatus\n";
   } else {
       print " undef status\n";
       INT_handler(" error: $chan->name!\n");
       abortProcedure ();
Re: CA.pm Andrew Johnson
Prev: Re: R3.14.9 access security and "no read access" w/caget Steven M. Hartman
Next: Re: How to use process variable Mauro Giacchini
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: user-supplied functions Benjamin Franksen
Next: Re: CA.pm Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
