Hi Pam,
On Tuesday 26 May 2009 18:05:17 Pam Gurd wrote:
> (copy of a message sent to Andrew last week)
(sorry, I was on vacation; your message was next in my queue).
> I am testing an API which uses CA.pm for Perl procedures. My
> specification says the procedure should abort when it loses
> any CA connections. So I've started a soft IOC, started this test
> procedure, and then stop the soft IOC when it tells me to. It sleeps
> for a minute to allow CA to really disconnect (and there is a message)
> but it never gets to the callback routine. (Actually, it gets there
> once during channel creation - but not when the channel really
> connects.) Am I doing something wrong here?
I have to admit that I've never tested the $SIG{__DIE__} hook with CA, but it
does work once a few issues in your Perl code are sorted out.
> my $channel = CA->new("TEST:DEV1:CUR", &connectionCallback);
You need to pass either a reference to your connection handler routine or its
name as a string, thus use \&connectionCallback or 'connectionCallback'. As
coded above, the routine is actually being called while evaluating the
arguments for CA->new() and as a result it's not being attached to the
channel at all.
> CA->pend_io(3);
If you're using a connection callback, you can't use CA->pend_io() to wait for
your connection to be made (it returns immediately, just as ca_pend_io() does
in the C API). I replaced that line with CA->pend_event(3); but you could
also restructure your code and put subsequent processing into the connection
handler as long as you only do it once even if the channel later disconnects
and reconnects.
> sleep 60;
I would discourage you from ever using sleep once CA is running; replace it
with CA->pend_event() instead to allow CA activity to occur during the delay.
With the changes above, I get the following output, which I think shows that
the callback is working:
testing connection for TEST:DEV1:CUR
TEST:DEV1:CUR is connected.
Stop the soft IOC and then press Enter
Wait 1 minute for EPICS disconnect
CA.Client.Exception...............................................
Warning: "Virtual circuit disconnect"
Context: "tux.aps.anl.gov:5064"
Source File: ../cac.cpp line 1121
Current Time: Wed May 27 2009 09:42:25.687166414
connection callback! undef status
error: CA=SCALAR(0x9e6b50)->name!
HTH, I'd recommend that you study the various .pl programs in base/src/cap5
for examples of how to use the Perl CA library.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
- CA.pm Pam Gurd
Re: R3.14.9 access security and "no read access" w/caget John A. Priller
Agilent E8257D Device Support? Gaul, Robert
<2009>
2025
2026
CA.pm Pam Gurd
<2009>
2025
2026
