1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Patch for RTEMS ColdFire uC5282
To: Tech-talk Techtalk <[email protected]>
Date: Tue, 2 Jun 2009 19:28:54 -0500
The ColdFire MCF5282 processor has a hardware fault that can be worked around only by disabling buffered writes. From the Chip Errata (MCF5282DE, Rev. 6, 5/2009):
SECF124: Buffered Write May Be Executed Twice
Errata type: Silicon
Affected component: Cache
Description: If buffered writes are enabled using the CACR or ACR
         registers, the imprecise write transaction generated
         by a buffered write may be executed twice.
Workaround: Do not enable buffered writes in the CACR or ACR registers:
           CACR[8] = DBWE (default buffered write enable) must be 0
           ACRn[5] = BUFW (buffered write enable) must be 0
Fix plan: Currently, there are no plans to fix this.
I've committed the change to the RTEMS CVS repository and attached a patch you can apply:
Attachment: patch
Description: Binary data
I ran into this bug in one of my ColdFire/FPGA designs -- some registers in the FPGA were getting written more often than I expected!
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Prev: RE: problem in epics installation Mark Rivers
Next: subArray processing Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
