Also, when you install Cygwin you need to explicitly install Perl, it is
not installed by default.
The list of Cygwin packages needed to build EPICS is listed here:
http://www.aps.anl.gov/epics/base/win32.php
-----Original Message-----
[mailto:[email protected]] On Behalf Of Andrew Johnson
Sent: Tuesday, June 02, 2009 9:50 AM
To: [email protected]
Cc: K. Kiranbabu
Subject: Re: problem in epics installation
On Tuesday 02 June 2009 06:05:14 Ralph Lange wrote:
> this looks as if perl is either not installed or not found on your
system.
> Please make sure you carefully read the parts of the documentation
that
> talk about software requirements.
To add to Ralph's comment, the perl interpreter needs to be on the
search
path. Since you are using the cygwin-x86 target you might find it
simpler to
use the Cygwin shell (bash) rather than Windows' command shell to build
Base.
- Andrew
> On 02.06.2009 10:57 K. Kiranbabu wrote:
> > Hello Guys,
> > I am new bee to EPICS. I tried installing epics for windows. i used
> > cygwin as the crosscompiler and epics .3.14.9 base. But when i tried
> > the make command in the installation procedure, i got some errors
> > saying certain files are missing . I am enclosing the screen shot of
> > the error i got and the file i followed to install epcis.Please do
> > find the below attached files. How to fix this , and get epics
> > installed sucessfully in the system.
> > Awaiting for an early response from you,
> > Thanks in advance,
> > regards,
> > K.S.KiranBabu,
> > Research Scientist,
> > SAMEER -CEM,
> > Chennai.
The best FOSS code is written to be read by other humans -- Harold Welte
- problem in epics installation K. Kiranbabu
- Re: problem in epics installation Ralph Lange
- Re: problem in epics installation Andrew Johnson
Patch for RTEMS ColdFire uC5282 Eric Norum
<2009>
2025
2026
<2009>
2025
2026
