I have set up a PV gateway, and the gateway is built against EPICS Base R3.14.10. When I brought up the gateway, I saw the following errors scrolling up in the log:
../../../../src/cas/io/bsdSocket/casDGIntfIO.cc: CA beacon (send to "172.21.40.20:5081") error was "Connection refused"
Jun 11 11:44:57 !!! Errlog message received (message is above)
The gateway was up, but not functional at all, I checked the gateway diagnostic panel, nothing was connected, including the gateway's internal PVs.
Any idea?
Jingchen
EDM / CA error: CA value callback('...'): No data, CA status The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES Carl Schumann
problem about environment variables under vxWorks-6.6 Andrew Johnson
<2009>
2025
2026
FW: PV gateway Jeff Hill
<2009>
2025
2026
