Subject: |
EDM / CA error: CA value callback('...'): No data, CA status The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES |
Carl Schumann <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 11 Jun 2009 10:42:04 -0500 |
We are getting the following error printed to stdout/stderr from an EDM
X-Y Graph:
In the error case above we are attempting to go through a gateway. We
also have the same EDM screen accessible from a location where no
gateway is required. For the no gateway case we don't get the error.
That would tend to point to issues with the gateway, but the following
point seems to contradict that theory.
On the machine which requires the gateway for access to the PV and on
which we run EDM and see the error we are able to use caget at the
command line to get the data without issue. Any ideas about what is
not well here? Thanks for your time.
Sincerely,
Carl Schumann
[Fwd: [Fwd: problem about environment variables under vxWorks-6.6]] Schoeneburg, Bernd
PV gateway Zhou, Jingchen
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
