1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: [Fwd: [Fwd: problem about environment variables under vxWorks-6.6]]
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 11 Jun 2009 13:54:43 +0200
Hi all,
my colleague Gongfa Liu has a question, but his mail-address seems to be on a black list....
here I foreward his email...
- Bernd
--- Begin Message ---
Subject: [Fwd: problem about environment variables under vxWorks-6.6]
To: bernd Schoeneburg <[email protected]>
Date: Thu, 11 Jun 2009 11:03:21 +0200
Gongfa Liu                         MKS-2, DESY
phone:  +49-40-8998-1642           Notkestr. 85
fax:    +49-40-8998-4388           22607 Hamburg
e-mail: [email protected]         Germany
Subject: problem about environment variables under vxWorks-6.6
To: [email protected]
Date: Thu, 11 Jun 2009 09:49:47 +0200
Hi, all,
I created an ioc application with makeBaseApp.pl for test under the following environment:
   epics base:          3.14.10
   vxWorks:             6.6
   target architecture: vxWorks-pentium
I got a waring message after iocInit:
   "The CA server's beacon address list was empty after initialization?"
This waring message is from ~base/src/rsrc/online_notify.c, I use epicsEnvShow(NULL) and epicsPrtEnvParams() to print the environment variables at the position where the warning message is created, but nothing is printed. It seems that the environment variables set is not inherited. What is missing in the vxWorks image? Any suggestions are appreciated.
Thank you.
Gongfa Liu
--- End Message ---
--- End Message ---
Prev: problem about environment variables under vxWorks-6.6 Liu, Gongfa
Next: EDM / CA error: CA value callback('...'): No data, CA status The requested data transfer is greater than available memory or EPICS_CA_MAX_ARRAY_BYTES Carl Schumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Using VDCT to add autosave info fields Alarcon, Arturo
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
