Hi Liu Ping,
As the developer of the DLS 8401 driver I guess I should respond!
However, the problem is nothing to do with the 8401...
On Tue, 16 Jun 2009, liuping wrote:
> As a fresh man, I need your help. The hardware is Hytec8002 and
> hytec8401. Hytec8401ip driver came from Diamond website. I made my own
> application project with EPICS V3.14.8.2 and VxWorks V5.5.1. The codes
> compiling is no error but some warnings. When downloaded to
> VME(mvme5500), there are some error message as below:
The trick is to focus on the *first* error:
> ## Load record instances
> dbLoadRecords("db/8401.db")
> value = 0 = 0x0
> # slot int options
> IPCAC6 = ipacEXTAddCarrier(&EXTHy8002, "6 2 10")
> Id: drvHy8002.c,v 1.10 2001/11/20 12:21:42 wscott Exp
> 8002 initialise 6 2 10
> PROM manufacturer ID: 0x8003 (HyTec Electronics Ltd., Reading, UK)
> PROM model #: 0x8002, board rev. 0x03
> PROM Xilinx rev.: 0x03, 0x00, 0x07
> PROM Serial #: 0x00 0x00 0x00 0x00 0x05 0xce
> drvHy8002filename="../.: A32 RegisterAddress error
> (status=./..34144267/src/libCom/)osi/devLib.c" line vmeslot number=282
> 6, ipslot unable to m0ap address VME A32 at address base=0X11800000800000
> size =
> 0X100000
> 0xIP memo1ef31290ry register (error!
> tShell): drvHy8002ipacAddCarrie: Cannot register A32 device at r:
> 1800000Hytec VICB8002. Error is driver retur209000bned an error.
This is where things have gone wrong. Unfortunately I don't know the 8002
configuration particularly well, so I don't know precisely what's gone
wrong. Also, you have two messages coming out at the same time, resulting
in interleaved text.
My best guess is that the 8002 isn't plugged into slot 6. Unfortunately,
if that's not the answer, I don't have any further ideas here.
Anyhow, focus on getting the 8002 to initialise properly first...
> new symbol "IPCAC6" added to symbol table.
> IPCAC6 = 0x1ee87ff0: value = -1 = 0xffffffff
Everything after this is broken!
- Re: "A32 RegisterAddress error" about Hytec8401 Andrew Johnson
- "A32 RegisterAddress error" about Hytec8401 liuping
Re: Installing Protocol Files Dirk Zimoch
<2009>
2025
2026
<2009>
2025
2026
