Hi Eric,
At PSI, we install then into a cfg/ subdirectory for each IOC.
When I was at DELTA, we installed them into a common protocols/ directory.
It a philosophical question, not a technical one. I would say wherever you
install templates (ioc boot directory or global pool) do the same with the
protocol files.
You can even do both, first look locally then in the pool. STREAM_PROTOCOL_PATH
accepts a list of directories (like PATH).
Dirk
Eric Bjorklund wrote:
Hello,
We are just getting started with StreamDevice and were curious to know
where other sites put their protocol files so that they can be
referenced by the IOCs that want them. Do you "install" them from
shared apps (like DBD's or scripts)? Is there an easy (or automatic) way
to set the STREAM_PROTOCOL_PATH environment variable based on the
definitions in the configure/RELEASE file? What is the current state of
the art in protocol file maintenance?
Thanks in advance,
-Eric Bj.
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031
email: [email protected] <mailto:[email protected]>
"The universe is full of magical things,
patiently waiting for our wits to grow sharper"
-- Eden Phillpotts
Correspondence
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Installing Protocol Files Eric Bjorklund
Re: "A32 RegisterAddress error" about Hytec8401 Michael Abbott
Re: "A32 RegisterAddress error" about Hytec8401 Andrew Johnson
<2009>
2025
2026
Re: Installing Protocol Files Tim Mooney
"A32 RegisterAddress error" about Hytec8401 liuping
<2009>
2025
2026
