Eric,
In our local copy of streams, we've added a 'protocols' directory, but I
don't think anyone's ever
used it. I think most people put protocol files in the same directory
as the first database that used them.
You can set the STREAM_PROTOCOL_PATH to anything in your cdCommands or
envPaths
file with, for example:
epicsEnvSet("STREAM_PROTOCOL_PATH","$(TOP)")
If this doesn't get you to the required directory, you could supplement
with a fixed path from there:
epicsEnvSet("STREAM_PROTOCOL_PATH","$(TOP)/abc/def")
Tim
Eric Bjorklund wrote:
Hello,
We are just getting started with StreamDevice and were curious to know
where other sites put their protocol files so that they can be
referenced by the IOCs that want them. Do you "install" them from
shared apps (like DBD's or scripts)? Is there an easy (or automatic)
way to set the STREAM_PROTOCOL_PATH environment variable based on the
definitions in the configure/RELEASE file? What is the current state
of the art in protocol file maintenance?
Thanks in advance,
-Eric Bj.
Eric Björklund
Los Alamos Neutron Science Center (LANSCE)
phone: 505-667-6031
email: [email protected] <mailto:[email protected]>
"The universe is full of magical things,
patiently waiting for our wits to grow sharper"
-- Eden Phillpotts
Correspondence
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group (www.aps.anl.gov/aod/bcda)
Advanced Photon Source, Argonne National Lab
- Installing Protocol Files Eric Bjorklund
Re: help for developing a simple application on EPICS Pete Jemian
RE: problem about environment variables under vxWorks-6.6 Mark Rivers
<2009>
2025
2026
Re: Installing Protocol Files Dirk Zimoch
<2009>
2025
2026
