Jeff,
Recall that if this is 3.14.10 on a little-endian architecture (e.g. Intel) then there is a bug that causes this message:
> "The CA server's beacon address list was empty after initialization?"
if EPICS_CA_AUTO_ADDR_LIST=NO
-----Original Message-----
Sent: Thu 6/11/2009 7:36 PM
To: Andrew Johnson
Cc: [email protected]
Subject: FW: problem about environment variables under vxWorks-6.6
Andrew,
I sent this message to tech-talk ([email protected]) some time back but maybe it didn't go through. I am suspicious because I sent another one later and it did go through (so this isn't maybe a delay related issue).
Jeff
Sent: Thursday, June 11, 2009 5:45 PM
To: 'EPICS tech-talk'
Subject: RE: problem about environment variables under vxWorks-6.6
If EPICS_CA_AUTO_ADDR_LIST is set to YES (the default) then the beacon address list is auto-configured using each of the network interfaces present on the local host. When fetching EPICS_CA_AUTO_ADDR_LIST, if envGetConfigParam returns a nill pointer, the server will decide to auto configure the beacon address list. So perhaps there is a 2nd possibility which might be that the system in question doesn't have any operable network interfaces installed?
Jeff
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Thursday, June 11, 2009 3:34 PM
> To: EPICS tech-talk
> Subject: problem about environment variables under vxWorks-6.6
> This message is from Gongfa Liu, I'm forwarding it while the APS sysadmins
> figure out why all email from DESY is being caught as spam... - Andrew
> Hi, all,
> I created an ioc application with makeBaseApp.pl for test under the
> following environment:
> epics base: 3.14.10
> vxWorks: 6.6
> target architecture: vxWorks-pentium
> I got a waring message after iocInit:
> This waring message is from ~base/src/rsrc/online_notify.c, I use
> epicsEnvShow(NULL) and epicsPrtEnvParams() to print the environment
> variables at the position where the warning message is created, but
> nothing is printed. It seems that the environment variables set is not
> inherited. What is missing in the vxWorks image? Any suggestions are
> appreciated.
> Thank you.
> Gongfa Liu
> Gongfa Liu MKS-2, DESY
> phone: +49-40-8998-1642 Notkestr. 85
> fax: +49-40-8998-4388 22607 Hamburg
> e-mail: [email protected] Germany
- RE: problem about environment variables under vxWorks-6.6 Jeff Hill
- FW: problem about environment variables under vxWorks-6.6 Jeff Hill
Re: Installing Protocol Files Tim Mooney
"A32 RegisterAddress error" about Hytec8401 liuping
<2009>
2025
2026
<2009>
2025
2026
