1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME 5500
To: [email protected]
Cc: GOURNAY Jean-Francois <[email protected]>
Date: Fri, 19 Jun 2009 09:21:14 -0500
Hi Jean-Francois,
On Friday 19 June 2009 06:25:29 GOURNAY Jean-Francois wrote:
> Whenever a C program has a misbehaved pointer, which causes a
> memory-write outside the allocated data memory, we have a crash of the
> CPU which is absolutely understandable, but then, it is impossible to
> reboot the CPU. Both flash banks containing the initial bootload and the
> VxWorks boot are corrupted and the only solution is to send back the CPU
> to the retailer !!! We had experienced this with several CPUs (we are
> probably bad C programmers) and didn't get so far any explanation from
> our retailers or after sales services. We have VxWorks 6.5.
Does this board have write-protect jumpers for the Flash?  Most of the other
MVME boards do, but I can't get to the hardware documentation for the
MVME5500 right now on the Emerson website so I can't check that for myself.
If it does they should at least be able to prevent the flash from getting
corrupted when things go wrong.
HTH,
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: MVME 5500 Rees, NP (Nick)
MVME 5500 GOURNAY Jean-Francois
Prev: Re: MVME 5500 Kate Feng
Next: Epics extension problems Pacios Rodriguez Luis Orlando
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: MVME 5500 Rees, NP (Nick)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
