Hello All,
This is a problem which not directly related to
Epics, but as several labs are using the MVME5500 CPU I hope that maybe someone
has encountered this problem and has a solution!
Whenever a C program has a misbehaved pointer, which
causes a memory-write outside the allocated data memory, we have a crash of the
CPU which is absolutely understandable, but then, it is impossible to reboot
the CPU. Both flash banks containing the initial bootload and the VxWorks boot
are corrupted and the only solution is to send back the CPU to the retailer !!!
We had experienced this with several CPUs (we are probably bad C programmers)
and didn’t get so far any explanation from our retailers or after sales
services. We have VxWorks 6.5.
Thanks in advance
J.F. Gournay
CEA Saclay
IRFU/SIS
- RE: MVME 5500 Feng, Kate
- Re: MVME 5500 Kate Feng
- Re: MVME 5500 Andrew Johnson
needs informations z abdou
Re: needs informations J. Lewis Muir
<2009>
2025
2026
<2009>
2025
2026
ANJ, 31 Jan 2014 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
