We do not have the problem with the RTEMS-mvme5500 BSP. In that case,
I just have to debug and rewirte the software and reboot the CPU.
However, for vxWorks, I think you should be able to reload the initial bootload and the
vxWorks boot yourself. Did'nt they send you the boot files ? I thought I reload the
those vxWorks boot files myself serveral times myself many yeras ago.
Cheers,
Kate
From: [email protected] on behalf of GOURNAY Jean-Francois
Sent: Fri 6/19/2009 7:25 AM
To: [email protected]
Subject: MVME 5500
Hello All,
This is a problem which not directly related to Epics, but as several labs are using the MVME5500 CPU I hope that maybe someone has encountered this problem and has a solution!
Whenever a C program has a misbehaved pointer, which causes a memory-write outside the allocated data memory, we have a crash of the CPU which is absolutely understandable, but then, it is impossible to reboot the CPU. Both flash banks containing the initial bootload and the VxWorks boot are corrupted and the only solution is to send back the CPU to the retailer !!! We had experienced this with several CPUs (we are probably bad C programmers) and didn't get so far any explanation from our retailers or after sales services. We have VxWorks 6.5.
Thanks in advance
J.F. Gournay
CEA Saclay
IRFU/SIS
- MVME 5500 GOURNAY Jean-Francois
Re: needs informations J. Lewis Muir
Re: MVME 5500 Kate Feng
<2009>
2025
2026
<2009>
2025
2026
