1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME 5500
To: GOURNAY Jean-Francois <[email protected]>
Cc: Gougnaud Françoise <[email protected]>, Lussignol Yves <[email protected]>, "Feng, Kate" <[email protected]>, [email protected]
Date: Mon, 22 Jun 2009 10:15:40 -0400
GOURNAY Jean-Francois wrote:
Hello,
I am curious to know what is the process to reload the MOTLoad of the MVME5500. I understand that you have to reload the VxWorks boot file, but what about the MOTLoad CPU monitor? Did you have to reload it?
I guess there was some confusion. I never had to reload MOTLoad. It should be always there. When I used vxWorks, there were two files. Each of them had to be loaded by following the vendor's procedure. One is boot.bin, and the second one is vxWorks. However, the reason why I needed to load them is because the board did not come with vxWorks. It was not because memory-write outside the allocated data memory. Memory-write outside the allocated data memory should not require one to reload the vxWorks or MOTLoad if the memory space was mapped correctly. I think it is because your vxWorks image was configured and/or built incorrectly. It probably maps the illegal space (e.g. the space of MOTLoad or flash memory) into the user programmable memory area. Maybe you can test this with someone who has a different built vxWorks image and see if this happens again. I hope this helps.
Cheers,
Kate
If yes, what kind of download device is required? Do you have the binary image of MOTLoad? Why did you have to go trough this process? (if you remember ...)
Jean-François
J.F. Gournay
CEA Saclay
IRFU/SIS
-----Message d'origine-----
De : [email protected] [mailto:[email protected]] De la part de Feng, Kate
Envoyé : vendredi 19 juin 2009 14:26
À : GOURNAY Jean-Francois; [email protected]
Objet : RE: MVME 5500
We do not have the problem with the RTEMS-mvme5500 BSP.  In that case,
I just have to debug and rewirte the software and reboot the CPU.
However, for vxWorks, I think you should be able to reload the initial bootload and the
vxWorks boot yourself.  Did'nt they send you the boot files ?  I thought I reload the
those vxWorks boot files myself serveral times myself many yeras ago. Cheers,
Kate
From: [email protected] on behalf of GOURNAY Jean-Francois
Sent: Fri 6/19/2009 7:25 AM
To: [email protected]
Subject: MVME 5500
Hello All,
This is a problem which not directly related to Epics, but as several labs are using the MVME5500 CPU I hope that maybe someone has encountered this problem and has a solution!
Whenever a C program has a misbehaved pointer, which causes a memory-write outside the allocated data memory, we have a crash of the CPU which is absolutely understandable, but then, it is impossible to reboot the CPU. Both flash banks containing the initial bootload and the VxWorks boot are corrupted and the only solution is to send back the CPU to the retailer !!! We had experienced this with several CPUs (we are probably bad C programmers) and didn't get so far any explanation from our retailers or after sales services. We have VxWorks 6.5.
Thanks in advance
J.F. Gournay
CEA Saclay
IRFU/SIS
MVME 5500 GOURNAY Jean-Francois
RE: MVME 5500 Feng, Kate
Prev: Re: Controlling multiple CAN busses Ralph Lange
Next: sigsev while creating new gdd in multiple threads Bruno Coudoin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MVME 5500 Feng, Kate
Next: Re: MVME 5500 Kate Feng
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
