Hi Yan Fen,
You have the PV loaded onto (at least) two nodes on the subnet
(or list of IP addresses in your EPICS_CA_ADDR_LIST) that edm is using.
Edm is behaving as it should, it's just getting two replies fo the
PV "X15U1:EH:DXP:Z".
This can also happen if you have a gateway and edm can "see" both the
source IOC's PV and the gateway's copy.
HTH
Dayle Kotturi [email protected]
Controls Department office 650-926-4923
SLAC National Accelerator Laboratory fax 650-926-3800
On Fri, 19 Jun 2009, ?? wrote:
Hi all,
I used edm-1-10-1zd, now I use related display to open another
interface. The interface is opened correct and the mistake display as
follows:
xtErrorHandler - Cannot convert string
"-adobe-helvetica-medium-r-normal--0-[+0.0+10.0~10.0+0.0]-75-75-p-0-iso8859-1"
to type FontStruct
CA.Client.Exception...............................................
Warning: "Identical process variable names on multiple servers"
Context: "Channel: "X15U1:EH:DXP:Z.BUSY", Connecting to:
10.30.53.51:5064, Ignored: localhost.localdomain:5064"
Source File: ../cac.cpp line 1224
errlog = 352 messages were discarded
Current Time: Fri Jun 19 2009 10:51:53.235893000
Why the message be displayed? How to solve it? Any suggestions are
appreciated.
Thank you!
Best wishes,
Yan Fen
Yan Fen
Shanghai Synchrotron Radiation Facility
Shanghai Institute of Applied Physics
Chinese Academy of Sciences
Zhangheng Rd 239,Pudong Dist.,
Shanghai 201204
China
Tel:+86-21-33933191
- Re: A problem about edm Kasemir, Kay
- A problem about edm 闫芬
RE: MVME 5500 Rees, NP (Nick)
<2009>
2025
2026
<2009>
2025
2026
