Hi all,
Thank you for your reply! The problem was solved.
Best wishes,
Yan Fen
----- Original Message -----
To: "Tech-talk" <[email protected]>
Sent: Saturday, June 20, 2009 12:54 AM
Subject: Re: A problem about edm
Hi:
Could it be that 10.30.53.51 localhost.localdomain is the
same computer?
I've seen cases on laptops, trying to access a soft IOC on the
same laptop, where I got multiple responses for the "real" IP
as well as 127.0.0.1.
The workaround was to set EPICS_CA_ADDR_LIST=127.0.0.1,
EPICS_CA_AUTO_ADDR_LIST=NO.
Kay
On 6/19/09 12:44 , "Dayle Kotturi" <[email protected]> wrote:
> You have the PV loaded onto (at least) two nodes on the subnet
> (or list of IP addresses in your EPICS_CA_ADDR_LIST) that edm is using.
> Edm is behaving as it should, it's just getting two replies fo the
> PV "X15U1:EH:DXP:Z".
> This can also happen if you have a gateway and edm can "see" both the
> source IOC's PV and the gateway's copy.
>> Warning: "Identical process variable names on multiple servers"
>> Context: "Channel: "X15U1:EH:DXP:Z.BUSY", Connecting to:
>> 10.30.53.51:5064, Ignored: localhost.localdomain:5064"
- Re: A problem about edm Kasemir, Kay
答复: A problem about edm 汪启胜
re: "A32 RegisterAddress error" about Hytec8401 liuping
<2009>
2025
2026
Re: A problem about edm Pete Jemian
<2009>
2025
2026
