1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Channel Access Portable Server, passing by pointer in read/write methods
To: <[email protected]>
Date: Thu, 25 Jun 2009 14:37:18 -0400
Hello,
I am considering the Channel Access Portable Server for supporting the C++ middle layer servers.
The associated PVs will maintain one-dimensional arrays of characters. Their lengths can be
significant.  So, passing by pointer in read/write methods would be a preferable way. The ‘write’ case
looks straightforward (as described in the tutorial, p.35):
class my PV : public casPV {
gdd* pValue;
caStatus myPV::write(const casCtx& ctx, gdd &value){
pValue->unreference();
pValue = &value;
pValue->reference();
The ‘read’ case looks trickier (Probably, because it is not explained).
In short, CORBA addresses such case by using the additional wrappers, e.g. gdd_var objects,
in the ‘read’ method. However, the signature of this method is already defined by the basis
class casPV. Fortunately, it seems we can still  use the gdd-based approach using another
mechanism, the pv-associated destructor, e.g. myPVReadDestructor:
caStatus myPV::read(const casCtx& ctx, gdd &value){
value.putRef(pValue->dataPointer(), new myPVReadDestructor(pValue));
where :
myPVReadDestructor::run(…){
Any comments and suggestions about a better solution.
Thank you,
Nikolay
RE: Channel Access Portable Server, passing by pointer in read/write methods Jeff Hill
Prev: Fanuc PMC Reflective Memory on MV2100 Ralph Lange
Next: a small tcl/tk script question Silver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Channel Access Portable Server, passing by pointer in read/write methods Jeff Hill
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
