1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Channel Access Portable Server, passing by pointer in read/write methods
To: "'Malitsky, Nikolay D'" <[email protected]>, <[email protected]>
Date: Fri, 26 Jun 2009 09:41:18 -0600
Nikolay,
For the write implementation what you have will work but you are allowing the client to change the GDD primitive type and application type structure of your service’s representation – which may or may not be appropriate in your situation. You end up with an un-typed service which could cause less predictable behavior. The client could for example change, using one write, a double value surrounded by lots of meta data into the string value “off” with no metadata for example.
For your read implementation the primary concern might be that the service wouldn’t be looking at some of the details of the read request from the client. In particular, the destination GDD comes preformatted with all of the application types that the client is fetching (i.e. all of the GDD application types in a CA DBR_XXXX – say DBR_GRAPHIC_DOUBLE), but your code snippet is substituting instead what the service is storing. Maybe this is ok as long as a superset of all of the application types is always provided (where the superset is modal depending on the DBR_XXXX data model for the value type of string, float, or enum). The client’s request would be rejected for example if the destination value has primitive type double and the substituted value is a string with value “off”. What you have suggested might be ok as long as you don’t mind leaving the error checking to the server. The server does do the necessary primitive type conversion checking of the response. If any of the application types are missing for the clients DBR_XXX type then the client’s read request is rejected.
The code in base/src/makeBaseApp/templates/caServerApp/exPV.cc shows another way to implement a read using a dispatch table for each of the applications types. I don’t claim that it’s the proper way to structure a service, but perhaps it can provide some contrast.
The GDD library also as I recall supports GDD container to GDD container assignment which would be another way to implement the read.
Jeff
From: [email protected] [mailto:[email protected]] On Behalf Of Malitsky, Nikolay D
Sent: Thursday, June 25, 2009 12:37 PM
To: [email protected]
Subject: Channel Access Portable Server,passing by pointer in read/write methods
Hello,
I am considering the Channel Access Portable Server for supporting the C++ middle layer servers.
The associated PVs will maintain one-dimensional arrays of characters. Their lengths can be
significant.  So, passing by pointer in read/write methods would be a preferable way. The ‘write’ case
looks straightforward (as described in the tutorial, p.35):
class my PV : public casPV {
gdd* pValue;
caStatus myPV::write(const casCtx& ctx, gdd &value){
pValue->unreference();
pValue = &value;
pValue->reference();
The ‘read’ case looks trickier (Probably, because it is not explained).
In short, CORBA addresses such case by using the additional wrappers, e.g. gdd_var objects,
in the ‘read’ method. However, the signature of this method is already defined by the basis
class casPV. Fortunately, it seems we can still  use the gdd-based approach using another
mechanism, the pv-associated destructor, e.g. myPVReadDestructor:
caStatus myPV::read(const casCtx& ctx, gdd &value){
value.putRef(pValue->dataPointer(), new myPVReadDestructor(pValue));
where :
myPVReadDestructor::run(…){
Any comments and suggestions about a better solution.
Thank you,
Nikolay
RE: Channel Access Portable Server, passing by pointer in read/write methods Malitsky, Nikolay D
Prev: Query Kallapur, Krishnamurthy
Next: RE: sigsev while creating new gdd in multiple threads Bruno Coudoin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Channel Access Portable Server, passing by pointer in read/write methods Malitsky, Nikolay D
Next: RE: Channel Access Portable Server, passing by pointer in read/write methods Malitsky, Nikolay D
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
