1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: medmCAExceptionHandlerCb: Channel Access Exception message
To: <[email protected]>, "Tech-talk" <[email protected]>
Date: Wed, 1 Jul 2009 08:04:19 -0500
David,
The medm message is "normal" because your IOC is exiting for some reason.  You need to find the reason for that.  It's strange that the IOC exits with no message, so it may be a bit difficult to track down.  It have not seen that.  Some systems are set up with an inactivity timer that will log you out after some period of inactivity, but that should kill your ssh session, not just the IOC application.
mark
-----Original Message-----
Sent: Wed 7/1/2009 8:02 AM
To: Tech-talk
Subject: medmCAExceptionHandlerCb: Channel Access Exception message
hello,
i'm running epics on a linux softioc and get the below error message
after the
ioc sits for a while. the application was built with epics base
3.14.18.2 and
with the following synapps modules/versions (if it matters):
autosave - 4-2-1
asyn - 4-9
calc - 2-6-3
motor - 6-4-2
seq - 2-0-11
sscan - 2-5-6
std - 2-6
medmCAExceptionHandlerCb: Channel Access Exception:
  Channel Name: Unavailable
  Native Type: Unavailable
  Native Count: 0
  Access: Unavailable
  IOC: Unavailable
  Message: Virtual circuit disconnect
  Context: ioc26idbpol.cnm.aps.anl.gov:5064
<http://ioc26idbpol.cnm.aps.anl.gov:5064>
  Requested Type: TYPENOTCONN
  Requested Count: 0
  Source File: ../cac.cpp
  Line number: 1142
basically, i ssh into the machine through exceed and launch the medm
screens as well
as the ioc (interactively). if i just let it sit, then after a few hours
(i've seen it fail
after ~2hrs and sometimes after 5hrs) the ioc returns to the linux shell
prompt (bash)
and the above message appears (no other messages).
has anyone seen something similar, know the cause, and resolution? ideas?
any help is appreciated.
please advise,thanks in advance,
/david
David M. Kline                   [email protected]
Beamline Controls and Data Acquisition (BCDA)
Argonne National Laboratory, Advanced Photon Source
Argonne IL, 60439                      630.252.8639
          Beamlines R Us -- EBRICKs Rule
Re: medmCAExceptionHandlerCb: Channel Access Exception message Eric Norum
medmCAExceptionHandlerCb: Channel Access Exception message David Kline
Prev: medmCAExceptionHandlerCb: Channel Access Exception message David Kline
Next: Re: medmCAExceptionHandlerCb: Channel Access Exception message Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
