On Jul 1, 2009, at 8:04 AM, Mark Rivers wrote:
David,
The medm message is "normal" because your IOC is exiting for some
reason. You need to find the reason for that. It's strange that
the IOC exits with no message, so it may be a bit difficult to track
down. It have not seen that. Some systems are set up with an
inactivity timer that will log you out after some period of
inactivity, but that should kill your ssh session, not just the IOC
application.
If the IOC is terminating unexpectedly you should try running it under
GDB and capture what's going on.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
- medmCAExceptionHandlerCb: Channel Access Exception message David Kline
- RE: medmCAExceptionHandlerCb: Channel Access Exception message Mark Rivers
Re: Prodex MAXv command responses (RA, QA, EA, RL) for different versions of firmware Ron Sluiter
<2009>
2025
2026
CA environment variables not being set? Shawn Smith
<2009>
2025
2026
