1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Detecting data lost from a subscriber
To: "Bruno Coudoin" <[email protected]>
Cc: [email protected]
Date: Thu, 9 Jul 2009 08:54:35 -0400
Perhaps I was not clear --
What if the client is trying to do something very slow with the monitors and is NOT consuming them at the same rate that the server is creating them.
This is the reason that rsrv for the EPICS database needs to start overwriting the last thing on the queue. It does not let the queue get over some specified size. If you just keep allocating memory and the client is not consuming the data fast enough, you use up your memory and eventually crash the system. At least I would expect this. It is likely a good idea to put something in to prevent this.
Bob
-----Original Message-----
Sent: Thu 7/9/2009 3:46 AM
To: Dalesio, Leo
Cc: Andrew Johnson; [email protected]; Ralph Lange
Le mercredi 08 juillet 2009 à 13:13 -0400, Dalesio, Leo a écrit :
> What do you do if the client is not consuming - but the server
>  continues to create arrays?
The same as for scalars, once they are sent or discarded the gdd will be
unreferenced by the CAS, but for arrays their gddDestructor will free
them.
Bruno.
RE: Detecting data lost from a subscriber Bruno Coudoin
Re: Detecting data lost from a subscriber Ralph Lange
RE: Detecting data lost from a subscriber Dalesio, Leo
Re: Detecting data lost from a subscriber Andrew Johnson
Re: Detecting data lost from a subscriber Bruno Coudoin
Prev: RE: Detecting data lost from a subscriber Bruno Coudoin
Next: RE: Detecting data lost from a subscriber Bruno Coudoin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
