Le jeudi 09 juillet 2009 à 08:54 -0400, Dalesio, Leo a écrit :
> Perhaps I was not clear --
> What if the client is trying to do something very slow with the
> monitors and is NOT consuming them at the same rate that the
> server is creating them.
> This is the reason that rsrv for the EPICS database needs to
> start overwriting the last thing on the queue. It does not let
> the queue get over some specified size. If you just keep allocating
> memory and the client is not consuming the data fast enough, you
> use up your memory and eventually crash the system. At least I
> would expect this. It is likely a good idea to put something in
> to prevent this.
I also had this case in mind but this is handled internally by the CAS
send process. If I understood it well, it just discards the new provided
GDD if the Queue for a particular client is full. Anyway, the memory
usage stay under control because the queue is limited.
Bruno.
- Re: Detecting data lost from a subscriber Andrew Johnson
- Detecting data lost from a subscriber Bruno Coudoin
- Re: Detecting data lost from a subscriber Ralph Lange
- RE: Detecting data lost from a subscriber Dalesio, Leo
- Re: Detecting data lost from a subscriber Bruno Coudoin
- RE: Detecting data lost from a subscriber Bruno Coudoin
<2009>
2025
2026
<2009>
2025
2026
