1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to IO registers from user-space in recent Linux versions
To: Till Straumann <[email protected]>, Mark Rivers <[email protected]>, [email protected]
Date: Thu, 09 Jul 2009 14:40:35 -0500
i haven't seen this issue with linux-based ebricks.....
cat /proc/version
Linux version 2.6.19.1-rt15 (root@iocdmk01) (gcc version 3.3.4) #4 PREEMPT Wed May 14 08:39:57 CDT 2008
/david
Till Straumann wrote:
The iopl(3) followed by 'in' works fine for me (both, when compiled -m32 or without)
till@tillbook:~/tmp$ uname -a
Linux tillbook 2.6.28-13-generic #45-Ubuntu SMP Tue Jun 30 22:12:12 UTC 2009 x86_64 GNU/Linux
#include <stdio.h>
#include <sys/io.h>
int main(int argc, char **argv)
unsigned char  v;
unsigned short p;
   if ( argc < 2 || 1 != sscanf(argv[1],"%hi",&p) ) {
       fprintf(stderr,"Usage: %s <port>\n",argv[0]);
       return 1;
   if ( iopl(3) ) {
       perror("iopl");
       return 1;
   asm volatile ( "inb %1,%0" : "=a" (v) : "d"(p));
   printf("0x%02x\n",v);
   return 0;
-- Till
Mark Rivers wrote:
Folks,
I have an EPICS application that directly accesses the parallel port (EPP) registers from user space on Linux. This is to communicate with an XIA Saturn spectroscopy module.
In order versions of Linux this worked fine if I ran the application as root, or by calling iopl(3) as root before exec-ing the EPICS application.
I am now trying to run this under a recent Linux (Redhat Fedora) version
baja:~>more /proc/version
Linux version 2.6.26.8-57.fc8 ([email protected])
(gcc version 4.1.2 20070925 (Red Hat 4.1.2-33))
#1 SMP Thu Dec 18 18:59:49 EST 2008
The EPICS IOC now crashes with a segmentation fault when trying to access the EPP port, even when running as root, and the following entry appears in /var/log/messages
Jul 9 11:43:44 baja kernel: dxpApp[27837] general protection ip:80a90a6 sp:ff8ea8ac error:0 in dxpApp[8048000+1f7000]
Does anyone know what one needs to do in recent Linux versions to get access to the IO registers from user-space?
David M. Kline                   [email protected]
Beamline Controls and Data Acquisition (BCDA)
Argonne National Laboratory, Advanced Photon Source
Argonne IL, 60439                      630.252.8639
         Beamlines R Us -- EBRICKs Rule
Access to IO registers from user-space in recent Linux versions Mark Rivers
Re: Access to IO registers from user-space in recent Linux versions Till Straumann
Prev: Re: Access to IO registers from user-space in recent Linux versions Till Straumann
Next: Re: Access to IO registers from user-space in recent Linux versions John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Access to IO registers from user-space in recent Linux versions Mark Rivers
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
