Till,
Your program works on my system accessing the EPP port (0x378).
So it must not be a security problem, it must be a problem with my code.
Thanks very much for sending the code.
-----Original Message-----
Sent: Thursday, July 09, 2009 2:06 PM
To: Mark Rivers
Cc: tech-talk; [email protected]
Subject: Re: Access to IO registers from user-space in recent Linux
versions
The iopl(3) followed by 'in' works fine for me (both, when compiled -m32
or without)
till@tillbook:~/tmp$ uname -a
Linux tillbook 2.6.28-13-generic #45-Ubuntu SMP Tue Jun 30 22:12:12 UTC
2009 x86_64 GNU/Linux
#include <stdio.h>
#include <sys/io.h>
int main(int argc, char **argv)
unsigned char v;
unsigned short p;
if ( argc < 2 || 1 != sscanf(argv[1],"%hi",&p) ) {
fprintf(stderr,"Usage: %s <port>\n",argv[0]);
return 1;
if ( iopl(3) ) {
perror("iopl");
return 1;
asm volatile ( "inb %1,%0" : "=a" (v) : "d"(p));
printf("0x%02x\n",v);
return 0;
-- Till
Mark Rivers wrote:
> Folks,
> I have an EPICS application that directly accesses the parallel port
> (EPP) registers from user space on Linux. This is to communicate with
> an XIA Saturn spectroscopy module.
> In order versions of Linux this worked fine if I ran the application
> as root, or by calling iopl(3) as root before exec-ing the EPICS
> application.
> I am now trying to run this under a recent Linux (Redhat Fedora)
version
> baja:~>more /proc/version
> Linux version 2.6.26.8-57.fc8 ([email protected])
> (gcc version 4.1.2 20070925 (Red Hat 4.1.2-33))
> #1 SMP Thu Dec 18 18:59:49 EST 2008
> The EPICS IOC now crashes with a segmentation fault when trying to
> access the EPP port, even when running as root, and the following
> entry appears in /var/log/messages
> Jul 9 11:43:44 baja kernel: dxpApp[27837] general protection
> ip:80a90a6 sp:ff8ea8ac error:0 in dxpApp[8048000+1f7000]
> Does anyone know what one needs to do in recent Linux versions to get
> access to the IO registers from user-space?
> Thanks,
> Mark
- RE: [APS Beamline_controls] Access to IO registers from user-spacein recent Linux versions Mark Rivers
- Access to IO registers from user-space in recent Linux versions Mark Rivers
- Re: Access to IO registers from user-space in recent Linux versions Till Straumann
Re: Access to IO registers from user-space in recent Linux versions John Sinclair
Re: Access to IO registers from user-space in recent Linux versions J. Lewis Muir
<2009>
2025
2026
Re: Access to IO registers from user-space in recent Linux versions David Kline
<2009>
2025
2026
