1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to IO registers from user-space in recent Linux versions
Cc: [email protected], tech-talk <[email protected]>
Date: Thu, 09 Jul 2009 15:55:51 -0500
On 7/9/09 1:08 PM, Mark Rivers wrote:
> Folks,
> I have an EPICS application that directly accesses the parallel port
> (EPP) registers from user space on Linux.  This is to communicate
> with an XIA Saturn spectroscopy module.
> In order versions of Linux this worked fine if I ran the application
> as root, or by calling iopl(3) as root before exec-ing the EPICS
> application.
> I am now trying to run this under a recent Linux (Redhat Fedora)
> version
> baja:~>more /proc/version
> Linux version 2.6.26.8-57.fc8
> ([email protected])
> (gcc version 4.1.2 20070925 (Red Hat 4.1.2-33))
> #1 SMP Thu Dec 18 18:59:49 EST 2008
> The EPICS IOC now crashes with a segmentation fault when trying to
> access the EPP port, even when running as root, and the following
> entry appears in /var/log/messages
> Jul  9 11:43:44 baja kernel: dxpApp[27837] general protection
> ip:80a90a6 sp:ff8ea8ac error:0 in dxpApp[8048000+1f7000]
> Does anyone know what one needs to do in recent Linux versions to
> get access to the IO registers from user-space?
Hi, Mark.
Is the iopl(3) call succeeding?  FYI, I noticed in dxp version 2-9 in
line 893 of dxpApp/src/drvDxp.c, the return status of the iopl(3) call
is not checked.
Also, some instructional documents I've read said, if using GCC, one
must compile with the -O option (?).
Lewis
Access to IO registers from user-space in recent Linux versions Mark Rivers
Prev: RE: Access to IO registers from user-space in recent Linux versions Mark Rivers
Next: POSIX signals in Epics Pearson, MR (Matthew)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Access to IO registers from user-space in recent Linux versions John Sinclair
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
