1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: sub routine record doesn't get value via INPD
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 15 Jul 2009 13:08:17 +0200
... the patch finally fixed it.
Thank you.
Peter
Andrew Johnson wrote:
> On Monday 13 July 2009 13:24:27 Dr. Peter Zumbruch wrote:
>> I have the following problem (EPICS 3.14.10 / Debian 4.0)
>> with this tiny database (minimized to my problem) .
>> Why don't I see the Value/Raw Value of "HAD:RPC:S1:M0:C9:ToTL" at the
>> input D of the sub record "HAD:RPC:S1:M0:C9:stToTL", which I try to
>> access at c-code.
> There is a known bug in the subRecord that comes with R3.14.10 which is
> documented on the Known Problems page for that release along with a patch to
> fix it.  Your symptoms sound fairly similar to what I remember seeing, so
> hopefully the patch will fix it (it's the 3rd item from the end):
>    http://www.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html
> - Andrew
 Dr. rer. nat. Peter W. Zumbruch
 EE - department / Controls group / GSI
 E-Mail: P.Zumbruch_at_gsi.de
 Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
 GSI Helmholtzzentrum für Schwerionenforschung GmbH
 Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
 Gesellschaft mit beschränkter Haftung
 Sitz der Gesellschaft: Darmstadt
 Handelsregister: Amtsgericht Darmstadt, HRB 1528
 Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
 Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
 Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
sub routine record doesn't get value via INPD Dr. Peter Zumbruch
Re: sub routine record doesn't get value via INPD Andrew Johnson
Prev: Re: CAEN SY127 and SY527 Dirk Zimoch
Next: uptodate version of modtcp? Burkhard Kolb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: sub routine record doesn't get value via INPD Andrew Johnson
Next: ANN: (no)fun-0-.4.1 Benjamin Franksen
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
