1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sub routine record doesn't get value via INPD
To: [email protected]
Cc: "Dr. Peter Zumbruch" <[email protected]>
Date: Mon, 13 Jul 2009 23:14:20 -0500
On Monday 13 July 2009 13:24:27 Dr. Peter Zumbruch wrote:
> I have the following problem (EPICS 3.14.10 / Debian 4.0)
> with this tiny database (minimized to my problem) .
> Why don't I see the Value/Raw Value of "HAD:RPC:S1:M0:C9:ToTL" at the
> input D of the sub record "HAD:RPC:S1:M0:C9:stToTL", which I try to
> access at c-code.
There is a known bug in the subRecord that comes with R3.14.10 which is
documented on the Known Problems page for that release along with a patch to
fix it.  Your symptoms sound fairly similar to what I remember seeing, so
hopefully the patch will fix it (it's the 3rd item from the end):
   http://www.aps.anl.gov/epics/base/R3-14/10-docs/KnownProblems.html
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
sub routine record doesn't get value via INPD Dr. Peter Zumbruch
Prev: Re: sub routine record doesn't get value via INPD Matthieu Bec
Next: Re: DB CA link to PROC field Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: sub routine record doesn't get value via INPD Dr. Peter Zumbruch
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
