1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sub routine record doesn't get value via INPD
To: "Dr. Peter Zumbruch" <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Mon, 13 Jul 2009 21:26:56 -0400
I'll retract my previous post (..)
Setting up your example gets me a different result though, the one you expect - The only part I miss is field(INAM, "mySubInit"), maybe something there? This is the outpout I got
epics> dbgf HAD:RPC:S1:M0:C9:ToTL
DBR_DOUBLE:         0
epics>
epics>  dbpf HAD:RPC:S1:M0:C9:ToTL 200
Record HAD:RPC:S1:M0:C9:stToTL called myStoreFcn(0x8415b58), thr 200, precord->d 200.000000
DBR_DOUBLE:         200
epics> dbpr HAD:RPC:S1:M0:C9:stToTL
A: 0 ASG: B: 0 C: 2 D: 200 DESC: store 0 0 0 2 DISA: 0 DISP: 0 DISV: 1 E: 0 F: 0 G: 0 H: 0 I: 0 J: 0 K: 0 L: 0 NAME: HAD:RPC:S1:M0:C9:stToTL SEVR: NO_ALARM
STAT: NO_ALARM      TPRO: 0             VAL: 200
Matthieu
On 07/13/09 20:40, Matthieu Bec wrote:
doubles need %lf to printf.
Could that be your problem ??
#include <stdio.h>
int main (int argc, char *argv[]) {
    double f=200.;
    float *pf = (float*)&f;
    printf ("%f\n",*pf);
    printf ("%lf\n",*(double*)pf);
    return 0;
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
sub routine record doesn't get value via INPD Dr. Peter Zumbruch
Re: sub routine record doesn't get value via INPD Andy Foster
RE: sub routine record doesn't get value via INPD Allison, Stephanie
Re: sub routine record doesn't get value via INPD Matthieu Bec
Prev: Re: sub routine record doesn't get value via INPD Matthieu Bec
Next: Re: sub routine record doesn't get value via INPD Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
