Hi Andy,
Peter didn't provide the full dbpr of the AO record (unfortunate) but assuming he has ESLO=1.0 (default), because he's using raw soft support and he has LINR set to LINEAR, RVAL is getting set to 200.
I tested his database on 3.14.8.2 (setting the sub to a calc) and saw D set to 200 as it should be. I wonder if his subroutine function is doing something bad like overwriting some record fields.
Stephanie Allison
> -----Original Message-----
> From: [email protected] [mailto:[email protected]] On Behalf
> Of Andy Foster
> Sent: Monday, July 13, 2009 4:35 PM
> To: Dr. Peter Zumbruch
> Cc: Epics Questions
> Subject: Re: sub routine record doesn't get value via INPD
> Hi Peter,
> The "dbpf HAD:RPC:S1:M0:C9:ToTL 200" is putting 200 into
> the VAL field of the AO record: "HAD:RPC:S1:M0:C9:ToTL"
> rather than the RVAL field. Thus, the RVAL field remains at 0.0.
> The OUT link from the AO record gets processed as a result of
> writing to the AO record:
> field(OUT, "HAD:RPC:S1:M0:C9:stToTL")
> This link causes the "200" to be placed in the VAL field of
> the sub record: "HAD:RPC:S1:M0:C9:stToTL".
> The sub record INPD field is looking at the RVAL field of
> the AO field which is still at 0.0.
> Cheers,
> Andy
> On Mon, 13 Jul 2009, Dr. Peter Zumbruch wrote:
> > Hi all,
> > I have the following problem (EPICS 3.14.10 / Debian 4.0)
> > with this tiny database (minimized to my problem) .
> > Why don't I see the Value/Raw Value of "HAD:RPC:S1:M0:C9:ToTL" at the
> > input D of the sub record "HAD:RPC:S1:M0:C9:stToTL", which I try to
> > access at c-code.
> > 1) The ingredients:
> > > record(ao, HAD:RPC:S1:M0:C9:ToTL) {
> > > field(DESC, "0 0 0 2")
> > > field(DTYP, "Raw Soft Channel")
> > > field(FLNK, "HAD:RPC:S1:M0:C9:stToTL")
> > > field(EOFF, "0")
> > > field(LOPR, "0")
> > > field(HOPR, "199")
> > > field(DRVH, "250")
> > > field(DRVL, "0")
> > > field(LINR, "LINEAR")
> > > field(OMSL, "supervisory")
> > > record(sub, HAD:RPC:S1:M0:C9:stToTL) {
> > > field(DESC, "store 0 0 0 2")
> > > field(INAM, "mySubInit")
> > > field(SNAM, "myStoreFcn")
> > > field(INPA, "0")
> > > field(INPB, "0")
> > > field(INPC, "2")
> > > field(INPD, "HAD:RPC:S1:M0:C9:ToTL.RVAL")
> > > field(INPE, "0")
> > The referenced C-Code:
> > > static long myStoreFcn(subRecord *precord)
> > > short thr;
> > > thr = precord->d;
> > > printf( "Record %s called myStoreFcn(%p), thr %d, precord->d %f\n",
> > > precord->name, (void*) precord, thr, precord->d);
> > > return(0);
> > > epicsRegisterFunction(myStoreFcn);
> > 2.) The test: (caput / dbpf)
> > > epics> dbgf HAD:RPC:S1:M0:C9:ToTL
> > > DBR_DOUBLE: 0
> > > epics> dbpf HAD:RPC:S1:M0:C9:ToTL 200
> > > Record HAD:RPC:S1:M0:C9:stToTL called myStoreFcn(0x80577b0), thr 0,
> > > precord->d 0.000000
> > > DBR_DOUBLE: 200
> > > epics>dbpr HAD:RPC:S1:M0:C9:stToTL
> > > A: 0 ASG: B: 0 C: 2
> > > D: 0 DESC: store 0 0 0 2 DISA: 0 DISP: 0
> > > DISV: 1 E: 0 F: 0 G: 0
> > > H: 0 I: 0 J: 0 K: 0
> > > L: 0 NAME: HAD:RPC:S1:M0:C9:stToTL SEVR: NO_ALARM
> > > STAT: NO_ALARM TPRO: 0 VAL: 200
> > 3. ) The (stupid) question: Why don't I get the value of
> > HAD:RPC:S1:M0:C9:ToTL at D? At VAL I see it.
> > Thanks for any explanation.
> > Peter
> > Dr. rer. nat. Peter W. Zumbruch
> > EE - department / Controls group / GSI
> > E-Mail: P.Zumbruch_at_gsi.de
> > Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
> > GSI Helmholtzzentrum für Schwerionenforschung GmbH
> > Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
> > Gesellschaft mit beschränkter Haftung
> > Sitz der Gesellschaft: Darmstadt
> > Handelsregister: Amtsgericht Darmstadt, HRB 1528
> > Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
> > Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
> > Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
- Re: sub routine record doesn't get value via INPD Matthieu Bec
- sub routine record doesn't get value via INPD Dr. Peter Zumbruch
- Re: sub routine record doesn't get value via INPD Andy Foster
<2009>
2025
2026
<2009>
2025
2026
