1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: c channel access
To: [email protected]
Date: Wed, 15 Jul 2009 22:46:44 -0700
I should add one other thing to my previous question of:
"What is the best way to write a program in C that has functions which do reads/writes on process variables that are passed to them as parameters?"
I would also like to be able to tell if a PV has changed. Basically I would like to use the same functionality as the sequencer, but use calls to functions instead of states.
Thank you,
Patrick
Re: c channel access Daron Chabot
Re: c channel access J. Lewis Muir
Re: c channel access John Hammonds
Prev: c channel access with functions Patrick Thomas
Next: Escaped strings from fullPathName.pl Pedersen, UK (Ulrik)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: c channel access Daron Chabot
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
