1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pseudo coloring of video stream
To: Emmanuel Mayssat <[email protected]>
Cc: epics <[email protected]>
Date: Fri, 17 Jul 2009 15:48:01 -0400
Hi Emmanuel,
We use the same solution. Our selection went to yorick that allows processing the data and comes with a very fast graphics package. That let us handle the rate we get out of our server (~22kB/frame at 30+ fps)
here's a link to yorick:
http://yorick.sourceforge.net
Matthieu
On 07/17/09 14:56, Mark Rivers wrote:
Hi Emmanuel,
For my new EPICS areaDetector software the video stream is delivered via
an EPICS waveform record.  There are several other records that describe
the frame size, data type, color mode, etc.
I've written a plugin for the ImageJ open-source Java application that
displays this video stream.  ImageJ has lots of nice features, like the
pseudocolor you are asking about.  It also has dynamic line profiles,
showing the intensity of a line cut through the image data that updates
in real time, the ability to capture frames into a 3-D buffer for
playback as a movie or stills, etc.
The EPICS + ImageJ solution can display more than 50 frames/sec at
640x480 resolution.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Emmanuel Mayssat
Sent: Friday, July 17, 2009 1:51 PM
To: epics
Subject: pseudo coloring of video stream
All,
This is not directly related to epics, but rather to operations of
control system.
We are using a video stream of 640x480 black and white.
Operators are interested in the intensity of each pixel. This
information is used for diagnostics.
The human eye being more sensitive to colors than to shade of gray, I
would like to implement a pseudo coloring algorithm. That is filter the
video feed (real time) and map pixel depth to a color table.
Is anyone using this?
(very common for laser commissioning I was told)
If so, let's talk!
Emmanuel Mayssat
650/793-0626
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
RE: pseudo coloring of video stream Cobb, TM (Tom)
pseudo coloring of video stream Emmanuel Mayssat
RE: pseudo coloring of video stream Mark Rivers
Prev: GE Fanuc David Dudley
Next: Re: GE Fanuc David Dudley
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: pseudo coloring of video stream Mark Rivers
Next: RE: pseudo coloring of video stream Cobb, TM (Tom)
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
