1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GE Fanuc
Date: Fri, 17 Jul 2009 15:50:20 -0400
Yes, I'd very much like to get in contact with your local expert.
We're looking at the AB ControlLogix and CompactLogix (particularly the
Compact) as well.  Also looking at the Siemens S7-300 and Yokogawa FA-M3
product lines.
They all definitely have advantages and disadvantages.
The real plus for the AB is it's support of CIP, which puts interfacing with
EPICS fairly easy.
The Siemens - well - it's Siemens - you either love them, or you don't.
Yokogawa certainly has an interesting product with the FA, for which there
is an actual EPICS IOC that directly executes on the thing (although I'm
told it's kind of expensive - I haven't seen any pricing on it).
The GE however, seems to have the kind of power and high point count
integration we're needing.  None of the other PLCs have high channel count
analogs (GE has 64 channel 16 bit), or high count Digitals (GE and Yokogawa
both have 64 bit DI's and DO's).
Other problem is space.  Only the GE is going to easily fit 19" rack spaces
efficiently.
Gotta expand my spreadsheet for comparison quite a bit.
David
On 7/17/09 3:22 PM, "Elliott Wolin" <[email protected]> wrote:
> Hi,
> We plan to use Allen-Bradley ControlLogix PLC's for our control system,
> but are using GE Fanuc core-duo cpu's for data acquisition. If you have
> any interest in the latter I can put you in contact with our local expert.
> Sincerely,
> Elliott
>  Those raised in a morally relative or neutral environment will hold
>    no truths to be self-evident.
> Elliott Wolin
> Staff Physicist, Jefferson Lab
> 12000 Jefferson Ave
> Suite 8 MS 12A1
> Newport News, VA 23606
> 757-269-7365
> David Dudley wrote:
>> I¹m over at BNL NSLS2 now, and have been given the task of providing
>> recommendations as to the types of PLCs to support.
>> I¹ve been looking at the GE PACSystems among others, and Bob has
>> suggested I should ask on the mailing list as to whether anyone has
>> experience in using the GE Fanuc family in accelerator controls.
>> David Dudley
RE: GE Fanuc Bryce Karnaghan
Prev: Re: pseudo coloring of video stream Matthieu Bec
Next: Job Posting Eric Berryman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: GE Fanuc David Dudley
Next: RE: GE Fanuc Bryce Karnaghan
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
